bearinf race is stuck!!!
Hammer it out using a drift from the other side of the wheel. The drift must be the same diameter as the bearing outer race. Apply some heat to make it easier. Never try to remove a bearing by putting pressure on the inner race.
Rob
Rob
I hate heating wheels.. But using a brass punch and tapping the bearing race slowly while rotating did mine. Just a small press fit is why I do not like using heat. (normally that is)
When replacing a bearing try this method:
1. put the new bearing in the freezer overnight.
2. using a propane torch, carefully heat up the hub where the bearing will fit.
3. place the now chilled bearing into the hub, it should almost drop in place.
speedracer138
Aug 13, 2007 05:49 PM
