94 zx6e
Old Jun 9, 2009 | 11:54 PM
shotime1994's Avatar
Default 94 zx6e
Hi I just bought a 94 zx6e it has 20k on it. It has been sitting for seven years in a garage because it needed new carbs, the previous owner had the carbs never put them on today I installed them my question is how can I hand crank the motor I put some marvel mystery oil in the cylinders so I would like to hand crank it a couple of times to lube the piston rings. Thanks. Andrew
Old Jun 10, 2009 | 12:16 AM
Good move on prelubing the rings, pistons and cylinders prior to hand cranking the engine over. Should be able to remove the right side timing cover, and hand turn the crank that way. Plugs removed, some MO injected into the cylinders, then slowly hand turn the crank. I have injected diesel into the entire engine before to let it sit and soak.
Welcome to KF.
Fremont250
Apr 18, 2006 04:58 PM
reem98
Mar 19, 2006 01:13 AM
aapaintballsupply
Nov 9, 2005 07:36 AM
nemethjames1
Apr 22, 2005 07:50 AM
Violet_Vixen
Mar 30, 2005 03:48 AM
