87 zl 1000
Old Jun 2, 2011 | 03:12 AM
Ron07yz250f's Avatar
Default 87 zl 1000
I am working on a 87 lz 1000 for a buddy, it would not heet up, i put in a new thermostat and flushed the coolant. when it is up to temp after a ride, if you turn off the key the fan stays running for 2 min. this is normal. but you can hear the coolant boiling. is this something to be worried about? I made sure that there was no air in the system by opening the bleeder on the thermostat housing. soo with that said should this be something to be looked into?
thanks Ron
Old Jun 2, 2011 | 04:14 AM
hmm, first thought is to check the water pump impeller. ie, lack of circulation Good luck and let us know. Thanks
Old Jun 2, 2011 | 04:22 AM
that was the first thing that i checked, it is in good shape and circulates great. the coolant that I drained out was clean. no grit, or rust. the old thermostat was stuck wide open. i replaced with a kaw original. the fan cycles like it should. it seams to only be boiling in the res tank.
deej
Jul 17, 2006 08:38 AM
c10
Jul 1, 2006 12:34 AM
Crystofr
Mar 26, 2006 03:26 AM
gotrice
Mar 23, 2006 01:49 AM
kf6zql
Ninja ZX-10R
Jun 5, 2005 12:52 AM
