14-15 tooth question...
Old Jul 20, 2005 | 02:56 AM
onewheel's Avatar
Default RE: 14-15 tooth question...
I run a DID chain and sprocket speiclest sprockets
Old Jul 20, 2005 | 04:30 AM
gotrice's Avatar
The 05 already comes with the 520. It has a 43t rear but i cant find what the small one is. Any one know?
Old Jul 20, 2005 | 08:06 AM
Remo's Avatar
We are geared at 15 / 43
Old Jul 26, 2005 | 03:49 AM
onewheel's Avatar
wow.. my stock gearing was 15 front and a 40 on the front
Old Jul 26, 2005 | 06:58 AM
Remo's Avatar
gotrice, you can do your own chain, but as far as the sprockets go, don't know if you will need any special tool for the front one. Just did my 4k service and the mech said that the 520 chains are good, but they don't last very long. So I'm thinking that I may change out my chain/sprockets when I change my tires just to keep everything nice and fresh. With me working at a dealer, they even said that they will hook me up on installation charges too [8D]
Old Aug 2, 2005 | 10:54 PM
onewheel's Avatar
the front sprockets are held on with a good sizes nut.. I think mine was like a 24mm.
If your not using a impact gun you will need to have a way to lock up the rear wheel cause it will trun the wheel with the bike in gear when you try to wrench the nut off.
Old Aug 3, 2005 | 12:08 AM
gotrice's Avatar
I should have my set this week. My LBS will do it for me for about $60. (an hour labor) I will have the bike back same day!! I dont mind spending the $$ to know its done right. So total price for everything will be 260. Not to bad. What speedo correction is everyone using? I think i will go with the yellow box.
Old Aug 3, 2005 | 01:24 AM
gotrice's Avatar
Here is a link to my rear sprocket that comes with my kit.
stealth sprocket gold
It come with a stealth front and a gold RK xring chain!!!
Old Aug 3, 2005 | 02:29 AM
Notstock's Avatar
I have this one on my R1 and it was plug n play. Easy install and easy conversion on there site. Just put in what you had (old sprockets) then enter the new set up and wahla it tells you what the seting are. http://www.speedohealer.com/eng/intro.htm
ORIGINAL: gotrice
thaxtondill
May 1, 2010 11:48 PM
mustang
Aug 31, 2009 12:26 PM
JasonFMX
Sep 28, 2008 03:11 AM
07 KLXER
Jun 12, 2008 12:14 AM
greenmachine
Aug 15, 2006 05:35 PM
