07 Ninja 250R won’t accelerate past 30mph?
Old Sep 25, 2009 | 09:00 PM
07250R's Avatar
Default 07 Ninja 250R won’t accelerate past 30mph?
I got my first bike recently and am having some issues that I hope you can help me with.
The bike is an 07 but only had 150 miles when I got it from a police auction. Given the low mileage it possibly had not been run for 1+ years. Needless to say I could not get it started when I got it home. First I tried fuel additives and carb cleaner to try to fix it without removing the carbs. I did it get it started but it still was not running well. I ended up pulling the carbs off, cleaning them fully, and putting them back on. While this did make a big difference I still don’t think it is quite right. I can get the bike to about 30 mph but it gets there far slower than it should, just doesn’t have any zip. Once there I am stuck, low and mid gears wont rev higher than about 6-7k and high gears bog down. I know the engine is still breaking in but it should be able to rev higher right? (even if not “recommended”)
As I mentioned, I am new to bikes so maybe I am missing something obvious but I appreciate any suggestions.
Old Sep 25, 2009 | 10:09 PM
95451's Avatar
Welcome To Kawasaki Forums.
Turn On Same Tunes And Enjoy The Ride.
Theirs a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometime It Takes A Little Longer Then Others. So, hang-in there. Have Some Fun
Old Sep 26, 2009 | 01:15 AM
A full carb cleaning to me is removing all parts and soaking overnight blow out with air and reassemble.
Double check your cable adjustments, does the choke work? If so what does the bike do? A stuck float will also cause a low speed predicament as well as any plugged fuel filters, screens etc. I prefer to install my gauges and verify the carb sync after a tear down to know for sure.
Welcome to KF
Old Oct 25, 2009 | 07:44 AM
fgk228's Avatar
air filter riped broken too old or need replacing, need filter fluid
high altitude
fuel switch on, fuel filter replace
did you replace the fuel
side note, replace all fluids and oils, just to be safe.
ohh and most likely the drug dealer before you stashed his drugs in the exhaust.
Old Oct 26, 2009 | 01:49 PM
williamr's Avatar
This is unlikely on a nearly new bike, but your symptoms fit split diaphragms in the carbs.
Another possibility, given the time it's been standing, is gunged up main jets
Rob
Old Oct 26, 2009 | 04:33 PM
jeffzx9's Avatar
Sounds like you cleaned the primary jets and maybe not the secondary jets (completely.) Agree with William^. You can burn through as much carb cleaner and fuel as you want, but there's no substitute for taking carbs off and removing (all) the jets. Use a very fine wire or stiff bristle to knock out the crud.
Kawasakirider2010
Aug 13, 2011 05:15 AM
barney67
Oct 3, 2010 10:24 PM
bmx_lar
Apr 13, 2010 10:06 PM
jloder_22
KLR250
Sep 13, 2007 08:45 AM
txparrothead
Sep 20, 2006 11:37 PM
