06 636 valve chatter.
Old Dec 18, 2006 | 05:42 AM
shinobi636's Avatar
Default 06 636 valve chatter.
I have a 06 636. I've noticed that some times I can hear the valves chattering. The bike has Kawasaki 10W40 in it. Should I be running a heavier oil (I live in Florida, so it's never really that cold). The dealer checked the valve lash at 600 miles, and now it has 1950 or so. I'm not sure if it's because the bike is so quite at idle, or what? All my other bikes are much louder than the 636. The bike runs great, no staggering, or anything else.
Old Dec 18, 2006 | 07:04 AM
markmeinteil's Avatar
Default RE: 06 636 valve chatter.
Valve noise is usually not a problem.
It's better that you have some clearance between your cam & valves causing some noise instead of having zero clearance ruining your cam, lifters, and valves. I would stick with 10W40. Maybe go with synthetic once you hit 3000m
Old Dec 18, 2006 | 03:34 PM
shinobi636's Avatar
Thanks Mark.
gcmnsu
Jan 6, 2009 04:46 PM
richshaner
May 13, 2008 02:37 AM
fivepointnine
Ninja ZX-7R
Nov 3, 2007 12:11 AM
boostedintentions
Sep 6, 2006 09:16 PM
