04 kx250f
Old Jan 14, 2006 | 07:30 AM
shyshadow's Avatar
Default 04 kx250f
hi, im new here, i'll try to explain this as short as i can. my 04 250f starts sometimes and other times it doesnt. checked out coil, stator, flywheel, cleaned carb, timing is dead on, has spark, everything checks out good. when i go to start the bike (and if it cranks) it backfires(which i know can be a timing thing, but its dead on). once it runs, its starts popping out the exhaust and sometimes flames come from it. i have a twin air system on it and when i place a rag in the air box into the carb and it cranks, there is no backfire or popping or flames. our local kawi dealer has a bike in there shop right now doing the same thing and they have tried everything and it still does the same thing. i talked to another mechanic and he told me to replace the timing chain and it should work. timing chain has been in for approx 1 year, but when you put the chain tightner in, the chain is tight. when i take the tightner out, it does not have the appearence of the chain streching. i have tried different ignitions and does the same thing. right now i have a racing vortex ignition on it. please help, very frustrated. any suggestions will be VERY appreciated. also i have an o5 head on the bike. bike runs good on top end, just bottom end bites. believe prob is in carb, could there be an air leak possibly. thanks
2broke2gofast
KX250 & KX250F
Aug 26, 2007 06:59 AM
vfrpilot
May 21, 2007 09:01 PM
2broke2gofast
Mar 7, 2007 08:17 PM
lescam
Jun 14, 2006 10:04 AM
patmandoo
Jun 11, 2006 11:21 PM
