03 zx9r problems starting after warm
Old Sep 26, 2010 | 01:38 AM
Kellywellz's Avatar
Default 03 zx9r problems starting after warm
My bike always starts up easily when cold and usually even when warm but every once in a while I'll shut it off and soon after go to start it and it will only keep cranking over, if I wait about 10-20 mins it willthen start bak up. The bike always runs perfectly when started. It has 10k miles on it.
Old Sep 27, 2010 | 07:29 AM
Welcome to KF
When was the last carb service? (Float height checks, carb cleaning, synchronization checks). Does the bike act like it is flooded when you do a back to back start up? Will a WOT (wide open throttle) work in this situation? Congrats on the mileage.
Old Sep 28, 2010 | 03:57 AM
Kellywellz's Avatar
thank you! the carbs have not been serviced just regular oil changes air filter etc.... it will not start with wot and it doesnt act flooded. someone told me possibly cdi box and someone else said starter solenoid. bike always runs perfectly smooth is why i havent done anything to the carbs.. and i havent owned it for a long time.
Old Sep 28, 2010 | 04:11 AM
I still am leaning towards a fuel supply issue or a plugged air filter.
Old Sep 28, 2010 | 04:17 AM
Kellywellz's Avatar
wouldnt electrical make more sense tho since its not happening often and only after the bike is hot, and the weather is hotter out
Old Sep 28, 2010 | 04:24 AM
That could be. What page in your manual is making you think this? Is this a vapor issue? Maybe because of poor venting and insulation? some unkowns again. Tossin' ideas out there. Electrical? ohm out the coils, plug wires. You could be onto something with staying with the basics.
Kellywellz's Avatar
oh and i definetely appreciate the help im not trying to tell u your wrong, just trying to figure this out
Old Sep 28, 2010 | 04:31 AM
dude, welcome again to KF.. I was just throwing out more ideas. I am a rider myself and was trying to see if I could help out.
drwmwatson
Jul 26, 2012 07:43 PM
Taipan
May 24, 2011 02:22 AM
schottsoccer
Apr 26, 2009 10:30 PM
jkarner
Sep 9, 2005 06:03 AM
