'03 ZRX1200 Fuel Line Replacement
Old Mar 11, 2012 | 09:27 PM
Kawzrx12's Avatar
Default '03 ZRX1200 Fuel Line Replacement
Hello All, sorry if this topic has been discussed before but I can't seem to find any threads about it and nobody has posted anything in over a month on the ZRX forum.
My '03 ZRX1200 needs the fuel line replaced. Wondering if anyone has any tricks/techniques as to how to remove and reinstall the 5/16" end on the fuel rail without removing the airbox. Also, what modifications can be done so that the petcock is 5/16" instead of the factory 3/8"? (So I can use common 5/16" fuel line)
Thanks in advance for any responses or links to existing info that I can't seem to find.
Old Mar 11, 2012 | 11:26 PM
3/8"? If so, there are 3/8" fuel lines readily available at your local auto store.
Do you have a pic of that end rail question?
Old Mar 11, 2012 | 11:34 PM
Kawzrx12's Avatar
Dragone#19,
Unfortunately, the fuel line on my ZRX has two different size I.D.'s. At the carb. or fuel rail the line is 5/16", in fact the line is 5/16" the entire length until it reaches the fuel petcock where it expands to 3/8". So if I use 3/8" line it will be loose at the fuel rail and if I use 5/16" line it will be too small to fit on the petcock. I have a factory replacement line but it seems impossible to get at the old line where it connects to the fuel rail without removing the airbox.
Old Mar 12, 2012 | 12:01 AM
ah, ok. That sounds messed up on the fuel line sizing.
I am not sure then without removing the airbox.
PAH
Mar 23, 2008 11:50 AM
sillyhillbilly
Nov 13, 2006 05:09 AM
slip
Oct 2, 2006 02:18 AM
slip
May 15, 2006 01:53 AM
slip
Feb 15, 2006 04:41 AM
