02 zx6r having trouble starting
Old Aug 27, 2007 | 04:47 AM
russell_pta's Avatar
Default 02 zx6r having trouble starting
hi all,
i have a 02 zx6r and over the last week i have been having trouble getting it started in the mornings. i will crank it for 4-5 seconds about 8-9 times before it finally fires up.
generally in the past i just give it a tiny bit of throttle and hit the starter and it fires within a second, now it takes several minutes. i feel like im hurting the bike running the starter this much.
any help would be greatly appreciated.
thanks,
russell
Old Aug 27, 2007 | 08:18 AM
Deuce's Avatar
Default RE: 02 zx6r having trouble starting
Shouldn't need to give it any throttle when it's cold. Are you using the choke or not? Plugs may be fouled, battery not holding enough of a charge. I'd check the plugs and battery.
Old Aug 27, 2007 | 12:14 PM
mmi86's Avatar
ORIGINAL: Deuce
2002.....does not usea enrichner circuit on the carb, bc its fuel injected, their for it doesnt have a choke,
Old Aug 27, 2007 | 01:54 PM
Deuce's Avatar
I've got the Haynes manual for the 95 to 02 models of zx6r (zx600 and zx636). Unless the manual lied to me, it's carb'ed.
Old Aug 27, 2007 | 05:04 PM
it's carbed. it has a choke. 02 was i believe the last year they did it. it actually started fine this morning, cranked right up.
Old Aug 27, 2007 | 10:32 PM
ORIGINAL: mmi86
ORIGINAL: Deuce
hmmmmm,
edit: there are carbs on that there ride. Was trying to post the fiche.
Old Aug 28, 2007 | 12:49 AM
mmi86's Avatar
haha nice
Old Aug 28, 2007 | 01:33 AM
zzrick's Avatar
I have to use the choke when it is cold outside, but not in the warm weather. Once in a while it seems to take a little longer to start though. How long did you have to crank it?
Old Aug 28, 2007 | 04:20 AM
today it was fine. i washed it a while back and maybe some water got into somthing. anyways, it seems to be starting fine now. i will write back if it happens some more.
thanks,
russell
Old Aug 28, 2007 | 04:27 AM
Where was that in your first post???
450guy
Sep 3, 2010 02:45 AM
MNrider
Mar 15, 2010 06:17 AM
dan888
Jan 24, 2010 03:15 PM
BlackNinjaZX6R
Jul 18, 2007 05:06 AM
