oil leak from air box, won't idle
Old May 6, 2009 | 12:43 PM
dtaggert's Avatar
Default oil leak from air box, won't idle
I have a 82 KZ440 that just started leaking oil from the air box drain tube. I changed the oil and I am sure I have the right amount of oil in it. The engine doesn't smoke or make any unusual noises when it runs. It also just started an idling problem. I've had a problem of fouling the left side spark plug so I removed the carbs and when I removed the top covers I found the diaphragm had a hole on the left side carb. I did a temp fix to the diaphragm (super glue) to see if that would help, it didn't. I can get it to idle for a few seconds but the longer it runs it will stop idling and die. I'm wondering if both my problems are related or do I need to replace the diaphragm assemblies on the carbs. Thanks for any advice.
Old May 6, 2009 | 03:09 PM
Zbike's Avatar
It could also be dirty pilot jets. Have you cleaned the carb jets yet?
Old May 6, 2009 | 03:38 PM
Is that an air filter that has oil? too much oil? Not supposed to have oil?
Old May 6, 2009 | 05:07 PM
jeffzx9's Avatar
It's all a related problem. You're getting crankcase oil "blow-back" into the airbox because there is a venting issue. Kinda like having a stuffed-up nose. I'm guessing there is/are some vent hoses or something which is blocked. Think of what an EGR valve does and you'll get the idea. It's there, somewhere...
SocialVirus
Aug 28, 2015 12:17 PM
fr4nci5q0
Mar 11, 2015 09:02 PM
Richard Avatar
Mar 26, 2014 07:34 PM
scat
Aug 21, 2007 03:06 PM
a16tony
Jan 21, 2006 06:43 AM
