My 95 Zx 9 Will not start when the bike sits in the sun.
Old Aug 27, 2009 | 10:58 AM
truckin1_99's Avatar
Default My 95 Zx 9 Will not start when the bike sits in the sun.
I had the problem and I changed the starter solenoid as I thought this was my problem. However I went to work yesterday and my bike sat in the sun for about all day (8 or 9) hours. When I went to start it up it turned and clicked. I tried again and It would only click. Can anyone tell me what this could possibly be causing this issue? Thanks in advance.
Old Aug 27, 2009 | 02:33 PM
Zbike's Avatar
Sounds like it needs a new battery. How old is the battery?
Old Aug 27, 2009 | 03:54 PM
jeffzx9's Avatar
Turn the key to the "off" position after trying to start. Move "Run/Stop" selector switch to "Run" position. Speak one-sentence expletive, twice in succession. Turn key to "On" position. Hit the start button.
If that doesn't work, check your battery, ground wire, ignition switch, side-stand kill switch, clip-on on/off switch, and starter connection. If you've replaced the solenoid, it sounds like a wiring ground "short" (of sorts.) My 9 will do this same thing occasionally. Battery is fine.
Welcome to the forums, truck! Gear up; stay safe.
Old Aug 27, 2009 | 05:06 PM
Default Will do
The battery is about 2 weeks old as I thought that was the initial problem. I will check the other connections as see what happens today. Thanks for the inputs.
Old Aug 28, 2009 | 12:50 AM
and this only happens when out in the sun and not after a long ride when you start it back up in an hour lets say? If you relieve the tank pressure will the ride turn over or still just click? (The cylinders are not hydrolocked after sitting that long?)
welcome to KF, was just tossin' other ideas out there. Generally it is a bad connection. Good luck.
AZR
Dec 28, 2012 04:51 AM
klx250s_rider
Dec 13, 2007 04:31 PM
markturbo
Dec 12, 2006 03:26 PM
condor55
Jul 8, 2006 12:29 AM
