KLX250 1993 aftermarket ignition switch?
Old Jul 12, 2018 | 07:04 AM
KLXRider250's Avatar
Default KLX250 1993 aftermarket ignition switch?
ive lost all my keys and have been searching everywhere for a aftermarket ignition switch for my KLX250E-1 1993, I know how to re-wire stuff but everything’s that I’ve looked at has been one or two wires more then mine. My current one has 4 wires. Genuine ignition switch is $150 and for such a old bike just want something that’ll work and also have the steering lock work as well, any body had this issue? Also can you buy just the key barrel? I’ve completely pulled the ignition switch apart and took the old key barrel out and now can stick a a screw driver in it and turn it on, off and lock. Need suggestions
Old Jul 12, 2018 | 07:46 PM
Welcome to KF
Take the lock to a locksmith and have new keys made.
Old Jul 12, 2018 | 10:46 PM
See if there is a code number on the lock mechanism. If so, contact a dealer and see if there is a way to get a key made. I don't know if there is. With Honda, there is a code and some key companies can make them from the code. Hope it can be done.
Old Jul 13, 2018 | 01:05 AM
Thanks all, I forgot to say that the ignition switch barrel had a screw driver stick in it and is completely broken
MaximusPrime
Nov 17, 2012 04:05 AM
jarel
KLX110
Jul 22, 2009 09:40 PM
esr98rs
Ninja ZX-7R
Sep 18, 2007 01:41 AM
aszrael1266
Aug 30, 2007 11:50 PM
walight01
May 5, 2006 02:00 AM
