Chain adjustment
+1 Jeff, been adjusting my chain on my dirt bike for 10 years on a stand. Thanks for the info for my 636 been looking for a thread tonight on how much tension becuase it looked a little sloppy.
I find the true slack required by the bike this way:
Now you can adjust your chain as the bike sits. It does not matter if it seems too loose, it isn't. It is better to run a bit loose than too tight. A decent chain that is loos will NOT derail, but a chain that is too tight can damage wheel or counter shaft bearings and cause premature chain sprocket wear, even chain breakage.
- Loosen the axle.
- Tie the rear of the bike down, pulling until the centers of the axle, swing arm pivot, and counter shaft are lined up.
- Adjust the chain until you have about 1-2" of play up and down about mid-way on the swing arm.
- To make sure the wheel is aligned, measure from swing arm pivot to axle, it should be the same on both sides.
- Tighten down the axle.
- Release the chassis to allow the suspension to extend.
- Measure how much play is in the chain now at a known spot along the swing arm.
- That measurement is what your proper adjustment should be.
