ER-6N Front brake lever travel
Greetings fellow Kawi enthusiasts.
I'm coming to you with a weird issue, that i couldn't find a conclusive answer for while searching.
The issue is, that my front brake lever has a huge "play" in it, it has to travel about half way until the brakes engage, after that point the braking power is decent enough for me.
What i tried and didn't help:
-Changed the brake fluid(was a little discoloured)
-Bled the system(had a little air, very tiny bubbles, very little)
-Adjusted the dial on the lever to the max position(on the minimum the lever almost touches the grip)
Additional info:
-The pads look fine, and bite quite good after the lever finally reaches it's point
-Got steel braided lines installed
-Discs look fine
Could be important:
While i was changing the fluid and bleeding the system, i had the reservoir cap off. When i was pulling the lever i noticed that until that half way point of engagement the pump is actually pushing liquid back into the reservoir like crazy. I was expecting it to return the fluid when letting go, but it's squirting when pulling.
These are the information i can supply, i hope that someone can help me. This is quite annoying and doesn't inspire confidence.
Additional info:
-Discs look fine
Could be important:
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
