DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
No oil pressure after oil change
Old 10-30-2018, 02:02 AM
BertF's Avatar
Default No oil pressure after oil change
Hello,
I have a 2012 Versys 1000, and after I change the oil I have a very hard time getting the oil pressure to come back. There must be an air lock happening at the oil pump. Does anyone have any answers as to why this is happening. Is there a special procedure to follow to prevent this from happening. Any advise is greatly appreciated.
Old 12-08-2018, 10:49 PM
I do not have a versys, so have you prefilled the filter with oil prior to engine start up?
Old 12-09-2018, 01:55 PM
BertF's Avatar
Yes I do pre-fill the filter, but that does not solve the problem. I have found out in the meantime that you need to leave the filter loose, start the engine and let it run until the oil starts to spill out, and then tighten the filter. I have tried it. It is a messy way of doing things , but it works.
Thanks for the reply.
Old 12-10-2018, 10:09 PM
Congrats on the fix.
MJohnson
Ninja ZX-9R
03-20-2011 03:17 AM
dboxman7
ZZR 600
09-19-2008 02:10 PM
Stubbz
03-28-2008 12:50 PM
j_christopherhall
07-25-2007 03:58 AM
bkkwolfe
01-09-2006 08:50 PM
Quick Reply: No oil pressure after oil change
