DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Jet Kit
Old Jun 30, 2007 | 07:01 PM
Deathmetal2890's Avatar
Default Jet Kit
i have an 05 ninja 500R and i am puting in the dynojet jetting kit. I already have the Jet's and needle'sin and now it is saying 2 drill out the fuel mixture plug. tryed 2 find it but the pic they give is ****ty.. not even sure if i have to drill it out because its dual carb and they only gave me 1 screw 2 replace it with.. anyone have any experiance with this???
Old Jun 30, 2007 | 07:37 PM
Default RE: Jet Kit
My take on this are getting the caps/plugs "drilled out" so that you can adjust the a/f screws.
If that is the case, I used a small punch to pierce and pry the cap/plug out.
Old Jun 30, 2007 | 10:17 PM
markmeinteil's Avatar
Old Jun 30, 2007 | 10:18 PM
Default RE: Jet Kit
Go to factory pro's website also. There should be more info on your bike.
Old Jul 7, 2007 | 07:27 PM
zzrick's Avatar
Default RE: Jet Kit
The screw they give you is to pull the plugs out after you drill the small holein the plug. PLugs are small brass things on the rear of carbs. Be very careful, if you drill through you will rund the screw inside all the way into carband need a rebuild. Make sure you are replacing the right jets also. No, I didn't make these mistakes, but I had amechanic help me install and he was full of jet-kit horror stories.
Old Jul 8, 2007 | 03:41 AM
mmi86's Avatar
Default RE: Jet Kit
ORIGINAL: zzrick
+1 ive seen some bad do it yourself jobs come in, the screw like zzrick said is to take out the EPA tamper proof blocks, drill a smaller hole then screw it in and pull straight out, NOTE when you are drilling GO slow very slow, soo slow you might fall asleep better safe than sorry
djchan
Aug 4, 2012 03:08 AM
Illking
Jan 24, 2011 11:34 PM
bootmud
May 22, 2010 02:38 AM
JazZ023
Aug 19, 2006 12:38 AM
zx6d
Nov 17, 2005 07:30 AM
