DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
How to Shave your Seat.
Old Oct 31, 2006 | 07:08 AM
speedracer138's Avatar
Default RE: How to Shave your Seat.
From the rear with a little dip. Sorry for the delayed response.
Old Jan 5, 2007 | 08:04 AM
steve214989's Avatar
Nice article. Just finished shaving my seat. Took a lot off it and it looks good. Just wanted to add a tip. If you are having a hard time getting the covering back on, or having trouble with an air pocket in the crtotch area. A carefull mix between the spray adhesive(super 77) and a heat gun will help. Heat the covering up so it is very flexible, glue it, then keep pressure on it until it tries. Be patient and let it dry before you take pressure of it. Good Luck.
Old Mar 3, 2007 | 08:30 AM
Yeah, that's what I used; Super 77. It looks good now that it's been used a bit. Steve, post your pics.
Old May 22, 2007 | 10:00 PM
hicktown's Avatar
whtas really the point of this??
Old Jun 4, 2007 | 07:25 PM
candylighting's Avatar
to keep your nuts from hitting the tank b.c of sliding forward on the seat. it holds you in place better when you shave the seat.
Old Jun 4, 2007 | 07:45 PM
Bluebeast's Avatar
That looks good speed. Sounds like it helps out.
Old Mar 27, 2008 | 01:40 AM
intense_05_636's Avatar
hey speed does this work for the 05-06 i know i have the same problems trying to stay away from the tank. and it does kill the wrists
Old Apr 3, 2008 | 11:16 PM
Yes, it should work on the 05-06's too.
Old Apr 7, 2008 | 06:24 PM
Jacked's Avatar
Make sure you use a power staple gun (not a hand-held one...)
A hand held one won't punch the staple through the thick (nylon I think it is?) base, unless I just have a weak old staple gun...
But any power staplgun should work fine (I was concerned that the power one might be TOO powerfull so I started off with a manuel one...)
Old Dec 17, 2008 | 05:40 PM
sup_uni's Avatar
bump to keep in thread
bayoubrew
Nov 1, 2012 05:37 AM
stumpjumper
Aug 1, 2011 01:07 PM
albany551
Sep 10, 2009 03:43 AM
harleyd1902
Apr 4, 2008 02:40 PM
Cstock
ZZR 600
May 29, 2006 04:00 PM
