DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Help
Old Sep 8, 2023 | 08:52 AM
Krazybitch71's Avatar
Default Help
Got a 2006 elemator and it REALLY NEEDS HELP AND I DONT KNOW WERE TO START
Old Sep 8, 2023 | 01:34 PM
Go on line and search for a free shop manual download. You're going to need it.
Do not try to start the bike until you take off the carbs and clean the float bowls. If you have tried to start the bike odds are some jets/passages will be clogged. I recommend having the carb bodies cleaned (can even be as assembled group of four, but all removeable bits removed) at a car or bike shop that has a carb washer or ultrasonic cleaner. You can't get in all the small passages with spray and sticking in wires can damage the passage.
Use the manual.
Old Sep 26, 2023 | 01:22 AM
onebus's Avatar
KLX678 is right. Start with the carbs also, get a battery, check the fuel tank for stagnant gas and rust or dirt. If it needs cleaning, they use viniger. If its rusted, you need to get it professionally done or pick up another tank. Then remove the seat and begin to sort out some of the wiring thats hanging but secure the carbs and the fuel system first. If you get stuck, come back here. We can help
Armenian70
ZRX1200
Jan 1, 2023 09:00 PM
EMS_0525
Jun 26, 2013 03:54 PM
EMS_0525
Aug 25, 2012 02:33 AM
avalaugh
Jul 2, 2008 06:47 PM
Unreal
Jun 27, 2007 04:37 AM
