DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Dual Headlight Mod for 03-05 ZX6R/RR & 04-05 ZX10's by speedracer138
Old Nov 13, 2007 | 05:03 AM
  #71
speedracer138's Avatar
Default RE: Dual Headlight Mod for 03-05 ZX6R/RR & 04-05 ZX10's by speedracer138
Sorry for the delay. The power only comes in through the low beam circuit and switches over by the relay when the High beams are selected. With my kit, the low beams go off when the Hi's are on to avoid an overload on the electrical circuit/ wiring system because both sides are on.
Old Nov 13, 2007 | 12:31 PM
  #72
ben_moo's Avatar
Ah right. Of course. Now that you say it, it's just obvious.
Thanks very much.
All you need sometimes is for somebody else to explane it a little differently, and everything just falls into place.
Old Nov 25, 2007 | 05:22 PM
  #73
superman63086's Avatar
Hey I want to do the dual headlight mod, and the LED internal turn signals. I was wondering if you have them for sale and if it would be cheaper for me to find and buy the parts to do it myself. Thanks Speed. Oh by the way this is one of the coolest mods on the zx so far.
pm me please.
06 zx-6r
6 1/4 extensions, 2in rear drop, 1 in front drop, jumper mod, integrated tail, arata slip-on, no front turns, mirror block offs, and soon to be TURBO
Old Nov 27, 2007 | 03:49 AM
  #74
Yes, I still have them for sale for $75 shipped. The LED Euro running/ turn signallightsare $35. Let me know. I haven't been putting them on ebay because I'm almost out of supplies but have a couple left.
Old Dec 10, 2007 | 07:46 AM
  #75
fahim's Avatar
mmmm i just did mine. looks hot!!
i blew one of my park light LED's when i turned it on for some reason, CBF taking it apart, im thinking blown LED. Let it be. Looks hot anyway. I'm waiting till it gets a bit darker so i can adjust my vertical light direction, then i will post up pics.
Thanks speed for all the help.
Old Dec 10, 2007 | 01:48 PM
  #76
fahim's Avatar
I have to admit, I think the ZX10R is a lot harder to do... because just getting to it required removal of the bottom, middle and top fairings, and I had to cut and lengthen the wires that went for the relay to the actual globes... i just hope they don't melt and catch on fire now...
heres hoping
all in all... completely worth it.
thanks once again Speed for the kit and all the help.
Old Dec 28, 2007 | 02:03 AM
  #77
Looks great! Sorry about the wires being short. I Might have messed up and sent the 636 harness. Glad you got it worked out and yes, the ZX10 is harder to do with removing the headlight &route the wires through. The wires are rated an 125 deg celsius so they'll be fine.
Old Jan 3, 2008 | 09:26 PM
  #78
05NINJAZX6RNH's Avatar
another kick a$$ job by speedracer...thanks again man
[IMG]local://upfiles/7611/741BC7AA9176462D91F648A60A193910.jpg[/IMG]
[IMG]local://upfiles/7611/15A8FAD95328421AB75593FBB2A7A028.jpg[/IMG]
Old Mar 21, 2008 | 04:46 PM
  #79
fahim's Avatar
looks good, i like ur screen
Old Apr 11, 2008 | 02:25 PM
  #80
wizzerdo's Avatar
has anyone here done the led signals on an 03? I tapped into the stock cables and turned the key on... they flash but do not stay on. If I connect to the wire that runs out of the ignition will they stay constant when the key is on? also, is the color the same on all years? I don't recall there being a brown w/ silver dot wire in there... i wish there was a wiring diagram somewhere
