DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Blinker Instal
Old May 26, 2011 | 11:10 PM
Breezy5's Avatar
Default Blinker Instal
I am getting ready to instal some aftermarket blinkers to my 2009 KLX250S. I have heard two different ways...1. just cutting blinkers at stalk and splicing new blinkers on right at that spot and 2. by tracing wire to fuse and pluging in if possable. Anyone have advice on instal and which is better? Just got this bike so I am unfamiliar with it and not electricaly inclinded.
Old Jun 10, 2011 | 06:17 PM
jacksonriding7's Avatar
From: In North Western Jersey, but from Jackson, WY Originally
These are effectively the same, just going further back the wire really. Most important thing is the quality of your connection and if you're switching over to an LED light. I like to solder and shrink wrap, some guys like crimp connections, my suggestion, if you're doing crimps use dielectric grease to keep them from rusting and use bullets they seem to hold better.
RE: LED's if you're switching to those you need to make sure they came with a resistor. You need that to keep it from lighting up both sides instead of just one. (I'll spare you the techy explanation part) of that unless you're doing LED and they didn't come with a resistor you dont need to stress it, if so, repost!
Old Jun 17, 2011 | 03:38 AM
Breezy5's Avatar
it all worked out. thank you for your information! Very helpful!
Old Jun 17, 2011 | 02:19 PM
I always use shrink tube to keep the crud out.
Old Jun 19, 2011 | 02:16 AM
I've always admired Deej and his crud free sparkly bike
Old Jun 26, 2011 | 01:15 AM
jeffzx9's Avatar
+1^ on soldered connections; butt connectors are for hacks. 3M makes an electrical joint wrap that is specifically for high-moisture exposed connections. I've used it on boat trailer wiring which gets submersed routinely. After soldering the connection, wrap it with the 3M stuff (about like bubble gum.) Then use Scotch 33 electrical tape; starting ahead of the joint, wrapping around tightly until you get past the joint to the other side. You can get the gummy stuff at Lowe's or Home Depot.
Mikefrommontreal
Apr 15, 2012 02:32 PM
pie4foou
Oct 3, 2007 02:10 AM
Hermolicious84
May 30, 2007 07:46 AM
BIG V
May 28, 2007 05:04 AM
deej
Apr 21, 2006 01:42 AM
