Detailing Discuss detailing your ride within.
Sponsored by:
Sponsored by:
kawa zx1100
Old Jul 3, 2007 | 03:27 AM
planeboy's Avatar
Default kawa zx1100
I people I have my bike that as soon as I slow down on the road for a light it stops. I start it right away no problem but have to keep a little bit of gas so it does not stop, in idle it runs not too good, I played with my rpm but when I adjusted it it runs in the 2000 rpm and does not go down.. I therefore cleaned my carbs, balanced all four carbs played with the mixing screw and still it does not work. When it's hot I let go the gas and it stops.
Anyone have more suggestion please for my problem?
Old Jul 3, 2007 | 03:38 AM
markmeinteil's Avatar
Default RE: kawa zx1100
Although unlikely, have you checked your timing to see if it's off? Otherwise, spray some ether (aka: starting fluid) around the carburettor boots and lines to see if the idle changes. If it does that would be a sign of a vacuum leak. One other thing to check is the float levels of your carburettor fuel bowls. make sure they are correct.
Old Jul 3, 2007 | 04:13 AM
Yeh continue with the basics. Check for vacuum leaks as mentioned and float level. But I have not had a level issue cause an issue when hot only though. Have you ran the choke up abit to check if it still runs when hot?
Richard
Oct 15, 2011 02:49 AM
TanksteR63
Apr 19, 2008 04:23 AM
TanksteR63
Apr 18, 2008 01:47 AM
alarmman15613
Ninja ZX-1100R
Nov 26, 2007 08:50 PM
dan52ohio
Jun 18, 2005 03:42 PM
