C10 Valve Adjustment Problem, Bad Valve
Old Jan 5, 2025 | 11:26 PM
fredtman's Avatar
Default C10 Valve Adjustment Problem, Bad Valve
I have a 2005 Kawasaki Concours with 26,000 miles.
When I started to do a valve adjustment the left side exhaust valve on the #1 cylinder was missing the screw and lock nut. I found the screw and lock nut in the upper part of the head and no visible damage could be seen. I was able to check and adjust the right side valve fine. But, when I tried to check the left side I could not even get the feeler gage under the tappet. I took that screw completely out and there was still no clearance to get the feeler gage in. I did not move the camshaft and the cam lobe is pointing away from that valve. Apparently there has been some damage done, but what? How do I determine what has happened and how do I fix it?
DavidNZ
Jun 6, 2019 04:20 AM
sizzlechest
Jul 30, 2017 11:35 AM
justtrust
Mar 28, 2014 03:59 PM
Bulletjive
Mar 30, 2008 09:27 PM
dcorlando
Oct 10, 2006 11:52 AM
