KE 175 b-3 1978 2-stroke smoker
Old Aug 29, 2010 | 08:16 PM
KE smoker's Avatar
Default KE 175 b-3 1978 2-stroke smoker
hello, does anyone know what charges the 6volt batt on this model? system is not charging all works with charged batt till it drains it. checked main fuse, all connections. thanks
Old Aug 30, 2010 | 06:49 AM
Prom's Avatar
Not sure, older bikes tend to have alternators but with the size of your's its probably a stator/rectifier unit. Check your manual to test the unit, should be an easy fix once you narrow it down.
Old Aug 30, 2010 | 07:49 AM
I do not have a 175 manual, but the rectifier or a bad connection is my first opinon as well. Welcome to KF
Old Sep 4, 2010 | 02:54 AM
KE smoker's Avatar
thanks, I am checking into the rectifier and regulator.
Old Jul 11, 2012 | 01:52 AM
dirtdawg1's Avatar
www.youtube.com/watch?v=4xJmpRsIZDYThis video shows how to replace the rectifier on a trail 90. It's a 6 volt system and the rectifier is a universal one from Radio Shack...costs about $4. Might be worth looking into if you find your rectifier is bad. If the link doesn't work, search on youtube for CT90 rectifier upgrade. Also, Oregon Motorcycle Parts Products has a step by step instructions on how to test a rectifier on their site, also might be worth a look.
soconor
Feb 3, 2026 06:14 AM
nicko
Classic Touring Bikes
Jun 26, 2015 09:27 AM
t20sl
Nov 19, 2010 11:18 PM
speedracer138
Feb 12, 2008 02:28 AM
sharris650
Jul 4, 2007 03:55 PM
