84 750 running rich?
Old Feb 16, 2010 | 01:04 AM
dragGPZ's Avatar
Default 84 750 running rich?
my 84 gpz 750 has a noticable hesitation at low rpms when you pin it it happens at about 3k or 4k but after that she rips. I have a feelin that the guy before me put different jets in and its running rich. she also smokes a lil cold starting but after that its fine no smoke. the hesitation does get a little better after its warmed up but its still noticable. i have no clue what jets are in there and what is stock. would anyone know what size stock is, or wtf else could be up wit this.
Old Feb 23, 2010 | 05:36 PM
What did you find out with the carbs and inspection?
Old Mar 11, 2010 | 09:16 PM
dragGPZ's Avatar
the carbs on the inside are spotless but stock jets are not it in at least im 98% sure there not the stock jets but they are 115 jets in there now, no clue what stock is, just want to take it back to stock and work from there. cannot find the specs for them anywhere online.
Old Mar 13, 2010 | 04:26 AM
dragGPZ's Avatar
seein its running fat i'm probably just going to slowly go down sizes on jets like 112 and so on and see where it puts me at
Old Mar 13, 2010 | 08:37 AM
I would be more concerned on a vacuum leak, or a fuel level adjustment first since the hesitation is in the 3-4k range and not while wide open. Double check your carb synch as well. Check in the manuals section here at KF. Don't remember if that ride was listed or not.
Old Mar 13, 2010 | 09:16 PM
dragGPZ's Avatar
my airbox has a couple cracks in it, possible solution? or just eliminate the airbox and put some pods on it. or would that mess up the jetting too much
Old Mar 13, 2010 | 09:18 PM
dragGPZ's Avatar
and how you get to the manual section?
Old Mar 14, 2010 | 09:13 AM
here is the link. Not sure if that info is in there but check it out. https://www.kawasakiforums.com/forum...ad.php?t=19450
I swore I have a factory manual on this ride. I need to look in my library.
edit: no 750 hardcopy manuals here.
Old Mar 14, 2010 | 09:25 AM
I generally prefer to keep the air box for most rides and not use pods.
Old Mar 15, 2010 | 04:06 AM
Prom's Avatar
doubt the airbox is the problem, and generally the harder you go on the throttle the more prevalent any problems with the jets would become. if you have ho problems on the high end I dont think it would be a jetting problem. However I cant suggest anywhere else to look...
