Valve adjustment Vulcan 800B
Old Jan 22, 2019 | 12:32 AM
8outof10's Avatar
Default Valve adjustment Vulcan 800B
How do I know if I have the correct TDC on the compression stroke?
Old Jan 22, 2019 | 01:43 PM
Pull the spark plug out of the other cylinder, then turn the engine until it comes up against compression. With the plug out there is no compression on the other cylinder.
To do the second cylinder put the plug back in, pull the plug from the first cylinder you did, the turn until it comes up against compression - same deal, with the plug out there is no compression with that first cylinder.
ERsixxer
Ninja 650R
Oct 27, 2015 12:31 AM
timbo213
May 12, 2015 10:05 PM
joeski49
Oct 8, 2013 04:05 PM
mikuniman
Classic Sportbikes
Jun 8, 2012 01:01 AM
joemeltn1
Jul 2, 2009 06:48 PM
