Starting issues.
Old Apr 21, 2010 | 12:39 PM
hans2112's Avatar
Hey all.... one other thing I want to ask.. What is the key switch supposed to do when turned all the way to the right in the Parking position? Cause this one does nothing-like that when I got the bike. Though I don't think theres a relation to my problem.
Old Apr 21, 2010 | 03:19 PM
Prom's Avatar
It just turns on the lights so people can see you when your parked, I never use it.
Old Apr 21, 2010 | 04:54 PM
hans2112's Avatar
I just began the metering process. The ign switch and starter switch appear ok. I got to the starter relay and it looked to have gotten hot on the relay to starter side. I had 12+ volts on the lead in. Then I but put meter lead on the terminal that leads to starter (assuming there should be 12+VDC going to the starter, and nothing). Its making noise and acting like a relay when I hit start button. I'm guessing its fried (Fuse hasn't blown).
Since this is set up alot like an old ford, can you jump across the relay terminals to see if the starter will crank? (without hurting anything). Lastly, I'm still leery about the ignition switch i.e: does it carry 12V through it on the way to the relay?
Old Apr 21, 2010 | 07:58 PM
hans2112's Avatar
I did try to run straight volts to the starter and nothing. So I pulled the starter and tried it on another battery and it worked fine. Soooo, taking the battery to dealer to get an official load test done. Would be crazy if its battery after all this. But it definintely would be a spontaneous battery death. Will update.
Old Apr 28, 2010 | 02:02 AM
hans2112's Avatar
Well, its a mystery to me, but,,, bought a new battery and whoom! I've never seen a battery spontaneously die. But I'm not asking questions.....time to ride!! Thanks for all the input--now I have another post to make...
Old Apr 28, 2010 | 03:31 AM
Prom's Avatar
Right on, sometimes a dead cell can wreak havoc on the system, glad you got it fixed brudah
matchless65
Sep 15, 2009 05:16 PM
ezrollin
Ninja ZX-7R
Feb 2, 2008 03:52 AM
wraith
Dec 17, 2007 04:43 AM
Gymratt500
Jun 2, 2007 04:22 PM
Birchmanjr13
Jan 7, 2006 07:15 AM
