whining noise after letting off throttle
Old Jun 2, 2011 | 02:09 AM
Originally Posted by erictomlin
pbrider...it turned out to be a failing bevel gear bearing. Replacing the bearing was an all day job. I had to remove the bevel gear case from the engine. The manual will tell you that you need to remove the engine, but you don't have to. You will, however, need to lift the back end of the engine up until the top hits the frame. Then you will have just barely enough room to get the bevel gear case out past the frame.
I used a "running journal" from another poster (on another site) as my instrucion guide. It was most helpful. Here is the link.
Vulcan/Mean Streak Bevel Gear Assembly
Check it out and let me know if you have any questions.
Thanks for the assistance on this issue and congrats on the fix.
Old Jun 17, 2011 | 01:20 AM
pbrider's Avatar
Thanks Eric, mine also was my bevel gear bearing. It was completely destroyed. My mechanic friend did the work, and did not have to remove the engine either. The link was totally helpful, because the Kawasaki manual says the motor needs to be removed. So thanks to all who put in their two cents!
pbrider
AZR
May 10, 2013 10:25 AM
pbrider
Jan 31, 2012 02:30 AM
hoehoho
Jul 7, 2009 02:50 AM
kawininja01
Aug 15, 2008 08:48 PM
Bujin2000
Sep 9, 2006 08:05 AM
