kx250 riders
Old 05-11-2010, 01:31 AM
kxrider863's Avatar
Default kx250 riders
hey i have a 99 kx 250 and the gears are a little stiff...........!!!=[
it doesnt have a clutch but i just bought 1 and i just got it in today and i had to get a new clutch cable so i have to install all this now i got this problem... any idea why it jus all of sudden is kinda stiff it will gear from 1 to 2 and thats about it!
Old 05-14-2010, 03:51 PM
james1984's Avatar
I think its better to put some grease on the gear.It will make it soft.Just try it.It will help you out.
Old 05-14-2010, 06:22 PM
Prom's Avatar
Not sure on your ride, I keep it on the streets but maybe I can help. You might be having trouble with your syncro's, try pulling in the clutch and apply light pressure to the shifter while varying the RPM. If you can get the engine RPM to match up with the wheels you should be able to get into a higher gear even without the syncs. If that works then you are going to need to tear into your gearbox to fix it.
Otherwise check your basics: cable length, adjustment, and lubrication could keep the clutch from engaging so make sure your clutch is actually working and that the shifter is mounted and adjusted properly.
Old 05-19-2010, 02:47 PM
Uhhhhh James? Can you tell us about yourself a little? Your posts are looking exactly like "angila" and they not only make no sense, but you both have a weird link in your signature and both of you have 5 posts that make no sense. I'm leaning toward banning you, so come on here and make an argument for yourself. I'm giving you 24 hrs to come clean or be purged.
Old 05-19-2010, 05:05 PM
Prom's Avatar
wow, was that really only 5 days ago? seems so long...
noimad1
KX250 & KX250F
48
02-10-2008 07:09 AM
George SA
KX250 & KX250F
08-26-2007 06:34 PM
asuhr@earthlink.net
KX250 & KX250F
07-13-2007 08:09 PM
noimad1
KX250 & KX250F
07-10-2007 10:37 PM
freestyle250r
08-27-2006 04:34 PM
Quick Reply: kx250 riders
