Debate
RE: Debate
Here is a black one its got a scuff mark on it but its 50.00 bucks Not sure what year it is. The add doesn't say.
http://cgi.ebay.com/ebaymotors/rear-...spagenameZWD1V
RE: Debate
come to buena park and ill meet up with you there, advanced is about 10 minutes from me and they do some kick *** work. great place to deal with and the guys in the back are extreamly knowlegable.
RE: Debate
cool, same place I got my beet system through. Feedback or conversations were good too from them. I just may keep the kit ecu, although have had a couple of responses on going wide band instead.
RE: Debate
going with a wide band controler might be the ultimate of the ultimate, at least with that you can do anything and still have the adjustability, more so over a pc3. and if you have a lap top and are comfortable with tuneing you can do it all on your own.
RE: Debate
ok, was told how to fix the fan issue for the kit ecu. It will function normally but a wire needs to be placed in the molex of the ecu to the harness. I am still not 100% sure on where, but it is doable. However, the wideband only logs the data and does not adjust the a/f. So a pc3 or the race ecu is still needed.
