I need help!! mechanics
Old 09-16-2008, 05:51 AM
boo727029199's Avatar
Default I need help!! mechanics
I just bought a 03 zx750r and I am in california..THe bike is from colorado..Runs alittle rough! please help I am told jets and a valve job? does anyone know the cost?
Old 09-16-2008, 12:56 PM
Hey welcome to KF,,, im not totally sure but elevation change could be causing your problem.. If so then rejet to the proper elevation that your at now.. Some others should be able to throw there 2 cents as well.. glad to have ya abord
Old 09-16-2008, 01:03 PM
welcome to KF. im no mechanic neither but what jrock said sounds right. the elevation change is pretty drastic. how many miles on the bike?
Old 09-17-2008, 08:56 AM
williamr's Avatar
I wouldn't expect any need for a valve job on an 03 unless it's a high mileage bike. The elevation change may have it running lean (needing re-jetting), but that wouldn't really cause rough running unless it's burning the plugs. You need to check this as excessively lean running will cause engine damage.
Without knowing what you mean by 'rough' it's hard to comment, but I'd start with the basics: new plugs. correctly gapped, air filter clean, and make sure that the carbs are in synch.
Old 09-17-2008, 02:06 PM
Welcome to the forums man.
Old 09-20-2008, 03:01 AM
yes, welcome to kf and see the "basics" of a ride. Stick around
Old 10-10-2008, 07:51 AM
whitehendrix's Avatar
welcome to KF!!
Old 10-10-2008, 09:55 PM
OMalley912's Avatar
Welcome also. let us know what happens.
Old 10-22-2008, 11:44 AM
Worlok14's Avatar
Start by re-jetting and install new plugs. Get a digital volt meter and check your plug wires for equal resistance. Check the fuel filter also. Always start with the cheap stuff first.
Welcome to KF man, and good luck!
Old 10-23-2008, 04:44 AM
oh, btw.. you're looking at 170 outties and 180 innies on those carbs on the main jets. if they've been changed, that'll be different..
check the jets, float levels, and make sure the mixture screws are where they should be.. or if the plugs are even there to cover the screws at all... if tey're gone, you KNOW someone was tweaking the bike, and i'd guess the A/F is WAY off..
Quick Reply: I need help!! mechanics
