Self diagnosis
Does it run?
Are you saying there is no code associated with a steady flash?
Is your battery going bad?
I don't have FI, but my dash went a little nuts when the battery was on it's way out.
You checked all the fuses?
Everything is plugged in?
Vibrations can take there time to wiggle a connector loose. I did an engine swap once, one wire harness connector wasn't fully seated and about 500 miles later I was on the side of the road scratching my head.
OK, that's all I got...
Paging the fuel injected crowd to the white courtesy phone, please.
Yep, it runs
There is nothing said about steady flash in the manual, it is unnormal...
Does it run?
