KLX choke relocation to handlbar
One of the control pods has a plastic plug that can be taken out and a choke lever installed in it's place. Any older street kawi probably has the parts you need(like a late 90's EX-500).
I get why you'd want to have it somewhere convenient, personally I like it all safe and sound and hard to find.
I've seen one KLR guy replace his choke lever with a KLX unit. A lot of KLR650 guys move them off the handlebar because they tend to break when the bike gets tired and dirt naps. Suggest you try to find a KLR unit to try, EXCEPT the darned cable connector into the carb is plastic and tends to break. There's a metal replacement connector out there somewhere. If I hadn't have just taken the cable cutters to it, I'd offer the one off my KLR because it was replaced with this: Kawasaki KLR 650 Choke Enrichner Cable Eliminator Over 300 Sold | eBay
Odds are you could get the choke cable, the plunger piston and parts from a 1995 Kawasaki KLX650C and fit it to the carb if it is the same seze. It runs up to a tab that attaches to one of the fork clamp bolts if I remember right. I moved it when I put on bark busters, mine is attached to the bark buster attaching bolt.
parts 49006, 16012, 920812D, and 16016,
