Front Axle Torque specs
Old 07-23-2006, 07:15 AM
ReaperFox's Avatar
Default Front Axle Torque specs
I have'nt recieved my service manual yet and was wondering if anyone would be kind enough to post up the torque specs for the front axle and the front axle retainer bolts for me?... I have the rear axle torque in my owners manual but can't find anything for the front. I'm in the process of mounting Kenda Trak Master II's as I write this!.
Thank you VERY much for anyone that can help!
Old 07-23-2006, 07:41 AM
Default RE: Front Axle Torque specs
The four front cap nuts should be 9.8 Nm and the axle itself should be 88 Nm (65 ft-lbs). Do the cap bolts finger tight first, then the axle, then tighten down the cap bolts. Be sure and get the speedometer mechanism in correctly during reassembly - there's a guide on the back side of the fork and two notches to engage inside the hub.
Old 07-23-2006, 08:17 AM
ReaperFox's Avatar
Awesome, thank you so much. .. Turns out I can't do the back tonight because I don't have a socket that will fit the rear axle nut, which surprised the heck out of me as I thought I had about everything at this point. But atleast the front is now changed and will be torqued soon.
Thank you again!
RDHJ
12-08-2009 07:59 AM
chris72a
04-22-2008 02:14 PM
kbekus
07-05-2007 06:26 AM
evil636
08-26-2006 05:24 AM
2001ninjaZX6R
07-20-2006 07:02 AM
Quick Reply: Front Axle Torque specs
