D-tracker front, rear Sprocket and chain
Hi guys i need to upgrade my front, rear Sprocket and chain. any suggestions?
Is this good for the rear sprocket?
DRC : Sprocket parts [D34-24-045]
Also this offer?
Kawasaki KLX 250S 06 on RK 520 Chain Supersprox Stealth Sprocket Kit Gold | eBay
Thanks
Also this offer?
Thanks
What gearing are you currently running Kenny?
I've got a 13, 14 & 15 front that I can swap between but I always end up coming back to 14/39!
I recon 15/42 would be good for the street. Then you could get the 42 Supersprox on the rear. btw Supersprox will do custom sizes for an extra $10 coz I got a 39 & officially they don't do smaller than 42!!
JT does a 39 tooth pretty reasonable. I got it on Amazon:
JT Sprockets JTR460.39 39T Steel Rear Sprocket
Sold by Kinney Cycles
Condition: New
$24.28, free shipping
Also picked up a 13 and 16 T cs sprocket and will likely pick up a 14 and 15 if I think it's worth doing. I believe I can fab up a case guard to work with the 16.
Condition: New
But Supersprox is not in the Webike list Motorcycle Parts & Accessories from Japan - Webike
kenny, that's just a basic (non O-ring) chain in that eBay kit. I'm also wondering about the listing stating - " '06 on " - since '09 up take a different front sprocket than '06-'07 do. And I think the rear sprockets are also different. Proceed with caution.
I think you will find it difficult to get a chain & sprockets kit for 14/40. btw I only like the 14/39 because I have a 331BB & can accelerate hard with 14/39. If I had a 250, I would be using a 40-42 rear sprocket.
All the D-Trackers (SF) are 14/39 & the S models are 14/42.
42R sprockets are easiest to find & to keep very close to your current gearing a 15F/42R would work well.
I would highly recommend a 0 or X-ring for a smooth long life!
These guys will customize any type of Chain & sprocket kit for you. They supplied my DID gold X-ring chain & contacted Supersprox for me to custom build a 39T rear sprocket for me. It's not obvious from their website but just email them & they can supply any combo you want. I got the DID ERT2 Gold & it has needed adjusting ONCE in 10,000km & still looks brand new....incredible chain!
SoloMotoParts.com - Motorcycle Parts, Gear & Accessories
Object
05-12-2008 02:15 PM
