2006 KLX250S Fork Spacer Mod
Another consideration when using either the spacers or heavier springs is that you cannot revalve or replace the rebound valve shims in the KLX forks to match the added spring tension.
Ride on
Brewster
Ride on
Brewster
Spacer size for KLX300 spring in 06 KLX250s
Does anyone have suggestions on spacer size for a KLX300 spring put into a 06 KLX250S?
There's a 15mm difference which is .59". I ended up having spacers that were right around .75" total in the end.
Also, the springs are heavy for my weight since I plan on doing more jumps. They're .46 rate when I'm 180 pounds, as opposed to the .42 or .44 more commonly suggested.
Would I benefit from using even bigger spacers and having more preload? I notice even with the stiffer springs, the front end still drops when I brake the front... but this is just a simple garage test with engine off... haven't tried on actual ride yet.
I believe I had 99 mm air above fork oil. What effect does more oil give? Makes springs even stiffer but less bottoming resistance?
Ride on
Brewster
I originally tried a pair of 1.25inch spacers & it just didn't make enough effect on the hard braking diving, so I jumped up to 2inch spacers a week later & that was much more noticeable.
