Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
Kawi Bayou 400 4X4 - Clutch
Old 11-25-2006, 02:09 AM
snurton's Avatar
Default Kawi Bayou 400 4X4 - Clutch
Hello Everyone!
We have a 1993 Kawasaki Bayou 400 4X4 - well used and has treated us GREAT.
The clutch is slipping now and getting worse to the point where it is time to do something.
Is changing the clutch a do it yourself project? In the Repair Manual ( Clymer ) there is two special tools for pulling the clutch.
The dealer tells me - yes it can be a do it yourself project but he orders the two tools from the factory when he needs them and then sends them back! ( no renting them )
Anyways I am going to drain the oil and remove the side plate and have a look..........
Any advice or information would be greatly appreciated!
Thank you in advance
Sean
Old 11-27-2006, 09:35 PM
meangreenman's Avatar
Default RE: Kawi Bayou 400 4X4 - Clutch
Probably the friction plates of your semi-auto clutch are worn out. I think you can do replace them at home if you can somehow hold the primary gear while unscrewing the balancer gear nut and oil pump drive gear nut.
hddi11
01-01-2015 09:07 AM
scottfourwheeler
03-11-2011 12:27 PM
Barnett22
08-06-2008 01:35 PM
txbroker
04-14-2007 08:07 AM
Quick Reply: Kawi Bayou 400 4X4 - Clutch
