Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
1997 STX 1100 Overheating!
Old 09-15-2009, 12:15 AM
JohnYeaw's Avatar
Unhappy 1997 STX 1100 Overheating!
I have a 1997 Kawasaki STX 1100 Jet Ski - it is overheating. I am wondering how I would go about solving this problem. It might be that the cooling system has been clogged with lake weeds (thanks, Lake Mead!). How would I check this? Can I remove the hose inside of the hull and clean it out that way? I am a little afraid of doing so unless someone with more experience can tell me if it is a good idea. THANKS much for any hints you can provide. One other thing.... it stalls repeatedly when first starting it. Is this just a sympton of a need for a tune-up?
Old 09-21-2009, 05:43 AM
jim pogue's Avatar
I would recomend removing the cooling water hose from the eng and use compressed
air to blow it back out thru to the jet if it is clogged. Another thing is check the hoses
at the jet and see if the are cracked or broken.Don't run it until this problem is cured
as you will cause major damage.
Jim
Old 09-21-2009, 05:03 PM
95451's Avatar
Welcome To Kawasaki Forums.
Turn On Same Tunes And Enjoy The Ride.
Theirs a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometime It Takes A Little Longer Then Others. So, hang-in there. Have Some Fun
Brennerw
05-31-2015 10:06 PM
SurfBeat
01-21-2015 02:20 AM
rob_1100
05-03-2011 04:27 AM
dandydon
10-22-2007 09:12 AM
rob_1100
03-08-2006 06:41 AM
Quick Reply: 1997 STX 1100 Overheating!
