K&N filter
Old Feb 29, 2008 | 08:06 PM
blackninja's Avatar
Default K&N filter
hey whats up guys, i need some help, I just finished replacing my old air filter and putting in an K&N filter but when i start my bike its like different, its seems like the idle is off or something, is there somthiung I could of done wrong< or do I need to adjust something else, please get back to me thanks. I have a Ninja ZX6 95
Old Feb 29, 2008 | 08:25 PM
Default RE: K&N filter
do you have a after market exhaust??
Old Feb 29, 2008 | 09:54 PM
OMalley912's Avatar
Is it in backwards, it's an easy mistake.
Old Mar 2, 2008 | 02:28 AM
zzrick's Avatar
If the filter is your only mod, it should be fine. What is wrong with the idle exactly? Did you maybe move the idle adjustment screw when you had the tank off? More info please.
Old Mar 3, 2008 | 07:44 PM
blackninja's Avatar
I dont have an aftermarket exhaust, and i dont think i put it in upside down, there is one side of the filter that says "this side up" and thats what i followed. and i just tried starting my bike now and it does not even start, it just keeps trying to but it doesnt actually start. i
Old Mar 3, 2008 | 08:30 PM
zzrick's Avatar
Are you using the choke? And is it cranking okay?
Old Mar 4, 2008 | 04:55 AM
blackninja's Avatar
when i used my choke, it did like the opposite effect, and instead of going higher it went lower< and turned off, it never did that before.
Old Mar 4, 2008 | 06:39 AM
ezrollin's Avatar
ORIGINAL: blackninja
Perfectly Normal on a cold engine!!
Sometimes when I turn my key to RUN it will crank.... and crank..... and crank..... and crank..... but NO Glory!!
Its the fault of the key-cylinder wiring.
I think that it is not making contact and the Ignition is not sparking. (my 1st guess)
or
maybe the fuel pump not pumping (my last guess)
GL!
Old Mar 6, 2008 | 01:32 AM
blackninja's Avatar
thanks guyz but i firgured it out< my stupid ***< didnt turn the valve that lets the gasoline flow on< i did that and it started fine.
Old Mar 6, 2008 | 03:59 AM
OMalley912's Avatar
Ahh...it's always something simply over looked eh?..Now go ride!
