-   Z750 (https://www.kawasakiforums.com/forum/z750-30/)
-   -   blinkers (https://www.kawasakiforums.com/forum/z750-30/blinkers-38563/)
Zanelo Jul 24, 2012 03:15 PM
blinkers
I just bought a 1982 Kawasaki ltd 750 and the blinkers come on and stay lit but do not blink...
What do I need to get them to blink?.. The hazard switch will not turn on the lights... Thanks for any information
deej Jul 24, 2012 08:55 PM
Your turn signal relay is probably shot. Pull one out of an older car and swap it out. ;)
Oh I forgot....welcome to the forums. :)
Dragone#19 Jul 25, 2012 02:35 AM
Also check your electrical connections for your turn signals. I have found that a loose connection can also cause the constant light issue. Physically pull each connection, blow it out and check for moisture or corrosion. Re-connect and move on. Yes, the relays do go out as well as deej mentioned.
Zanelo Jul 25, 2012 02:18 PM
Thanks for the information... I'll get right on it and let u know my status... As for the hazard switch? I'm guessing the switch to the right of the blinkers is in fact for hazards?
