blinkers
I just bought a 1982 Kawasaki ltd 750 and the blinkers come on and stay lit but do not blink...
What do I need to get them to blink?.. The hazard switch will not turn on the lights... Thanks for any information
Also check your electrical connections for your turn signals. I have found that a loose connection can also cause the constant light issue. Physically pull each connection, blow it out and check for moisture or corrosion. Re-connect and move on. Yes, the relays do go out as well as deej mentioned.
