Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
took the bike to track for 1st time
Old Jul 2, 2007 | 06:31 PM
fiv3ptsl0w's Avatar
Default took the bike to track for 1st time
05 636 full Akrapovic exhaust
best runs
12.08 @ 122mph.... popped the front tire shifting to 2nd...
12.00 @ 122mph.... wheelied it through 1st...
i could not get my 60' under 2.3....
Old Jul 2, 2007 | 07:29 PM
BurntOrange's Avatar
Default RE: took the bike to track for 1st time
That sounds like fun. I wonder what I could get out of my Nomad?
Old Jul 2, 2007 | 11:04 PM
projectroc's Avatar
Drop your 60ft time to a 1.8-1.9ish and you would be 11.00's no problem. If you want to launch harder, lower the front and rear 2"...then strap the front end down and you should be able to launch it without being so wheelie happy.
Old Jul 3, 2007 | 12:10 AM
fiv3ptsl0w's Avatar
ORIGINAL: projectroc
lower the front and rear 2"....
would thatmean getting new suspension? because i have no $$.. sucks...
i already have to buy a chain guard and leather pants before i go out next time.
Old Jul 3, 2007 | 03:05 AM
768 Ryda's Avatar
strap the front end and lower the rear and work on your 60ft. times and u will get faster
Old Jul 3, 2007 | 04:59 AM
ORIGINAL: fiv3ptsl0w
Not new suspension, just drop the front in the triples, lower the rear. The straps may set you back some and if you need lowering links, then that too will set you back a couple of penny's
Old Jul 3, 2007 | 05:00 AM
projectroc's Avatar
It would just mean buying some lowering links for the rear, and a front strap plus mounting brackets. Should be less than 150.00 worth of mods
Old Sep 5, 2007 | 05:55 AM
Big O's Avatar
My first first time on the track here in Germany at the Hochenheim ring was awsome!! We do the circuit tracks over here so when you lower your suspension you can't press in the curves like the bike is made to do. Try racing with 30 other ryders on the track with a drag bike. Its a hole different animal. But for dragg lowering is perfect! Keep em on two Guys!!
Old Sep 5, 2007 | 11:01 AM
BlackNinjaZX6R's Avatar
yeah if you want to limit your bike to a drag bike then lower it otherwise dont
Old Sep 5, 2007 | 11:46 PM
ORIGINAL: Dragone#19
Set your sags first before lowering the ride. Make sure the springs are for your weight.
