Pictures of new Seat Concepts saddle
I finally got around to replacing my seat. What a difference! It's like going from a padded folding chair to a La-Z-Boy.
I went with the Gripper top and vinyl sides with red thread. I also went with a slightly softer foam since I'd like to do more road trips on it. The gripper top is better then the stock seat. I also really like not having that ridge where the strap used to be. It's nice having it flared out a little more where I sit too.
Installation was a breeze. It took maybe a hour in a half. Most of that time was removing the old cover and prepping the pan for the new one.
The only thing I'll need to get used to is the roll when I accelerate. Because the stock seat was so firm you stayed in place when you accelerated. With this seat I feel myself being pulled back on acceleration and forward on hard stops. Again, minor differences and something I'm sure I'll get used to and adjust.
Actually, if you look at the two seat they appear different. Follow the stitching to the tank and you'll see what I'm saying.
Definitely look different to me. Looks like the red one is much thinner towards the tank, as compared to the green one. Are both of these bikes '09 or newer??? Could be a difference in the model years...
OK, that explains it. Mine is a 2012.
Good question! I'm 5'11" and before I could be close to flat-footed on the ground. Now I'm on the ***** of my feet. It's not so much the seat height as it is the width. The stock seat was so narrow it rode ride up in your crotch. This one is more of a seat and wider at the crotch.
