quarter-turn throttle?
Old Jun 13, 2012 | 01:02 PM
djchan's Avatar
Default quarter-turn throttle?
It occured to me last evening as I was trying to loft the front wheel in 2nd...
The KLX could benefit from a quarter-turn throttle. At least those of us who don't have a pumper carb know what I mean. It's a drag trying to wrack the throttle that hard.
Anyone have one? Results?
Old Jun 13, 2012 | 03:00 PM
CousinLarry's Avatar
Yes, and I love it. I have the MOtion pro one - good way to spend $25.
Old Jun 13, 2012 | 04:26 PM
cegusman's Avatar
Do you have a link to the motion pro one? Know if it will fit the 09?
Old Jun 13, 2012 | 05:19 PM
I believe this is the one I used:
MOTION PRO VORTEX THROTTLE KAWASAKI KX 125 250 92-08 | eBay
It gets rid of your second throttle cable - so if you don't want to do that, don't get it.
FWIW, I've had this almost as long as I've had the bike (~4yrs) with no probs.
Old Jun 13, 2012 | 05:31 PM
ahnh666's Avatar
what does it do?
Old Jun 13, 2012 | 05:53 PM
Pogiboy's Avatar
Is it easy to install. Close up Pics of it on your bike if its ok with you. Thanks.
Old Jun 13, 2012 | 06:21 PM
ahnh666 - In short, makes it so you have to twist less to get to full throttle.
Easy install, no pics, but nothing to see really..
Disconnect both throttle cables from stock tube
Remove stock tube assembly
Remove the "push" throttle cable completely
Slide on the vortex throttle, connect "pull" throttle cable
Ride like the wind - na na na na, na naaa naaaaa!
Old Jun 13, 2012 | 06:27 PM
ahnh666's Avatar
ah..i already have one on my klx....hehe...have the cheap plastic oem one in a box....
Old Jun 13, 2012 | 11:18 PM
Lutz's Avatar
It will fit on an '09, but not without modifying the wiring harness and/or getting a different on/off/start switch. There's a thread here somewhere on how I did it.
Edit: here's the link: https://www.kawasakiforums.com/forum...tle-kit-35705/
Old Jun 13, 2012 | 11:24 PM
teamgreenrider91's Avatar
is that like the same exact one you have on your bike? the picture just looks a little cheesy to me it looks like a cheaply made piece. but if it is a real motion pro product then i may have to give it a shot
