Changing Speedo LCD color
Old Jun 8, 2012 | 02:24 AM
WHIP-N-DIP's Avatar
Default Changing Speedo LCD color
Is it possible? I wasn't sure if there was a thread on this already but if there is please delete!
Old Jun 8, 2012 | 07:03 PM
rgoers's Avatar
The S and SF use different color back-lighting (S=white, SF=blue). That's the only way I know of to change the color... I think they're very different units thiough, and cannot be inter-changed
Old Jun 8, 2012 | 07:58 PM
ol'klx-er's Avatar
The SF is calibrated for the 17" front wheel, S for the 21" wheel. A SpeedoHealer (or some such device) might be able to compensate?
Old Jun 8, 2012 | 10:26 PM
rgoers's Avatar
Heck, I had to use a SpeedoDRD to compensate on mine, and my setup is stock S speedo with stock S front wheel...
Old Jun 9, 2012 | 02:13 AM
ol'klx-er's Avatar
Since I haven't tried to get my speedo to read correctly, I don't know how much those devices can adjust the reading.
Old Jun 9, 2012 | 04:28 AM
WHIP-N-DIP's Avatar
should be sometihng along hte lines of just chanign out the display bulb within the unit? i thought it'd be something so simple along the lines of that..
Old Jun 9, 2012 | 02:29 PM
ol'klx-er's Avatar
You'll have to be the pioneer. No one else has taken the instrument cluster apart far enough to see if that's all it takes to change the display color.
Old Jun 9, 2012 | 05:37 PM
rgoers's Avatar
It is likely a back lit LCD display. It probably uses several LEDs to light it. How are your soldering skills...???
Old Jun 9, 2012 | 07:17 PM
WHIP-N-DIP's Avatar
Never soldered but i know someone who probably could.
Neosporin
Aug 23, 2014 05:27 AM
texengland
Feb 28, 2011 04:46 PM
eclipsehunter2001
Oct 26, 2006 12:24 AM
bryantjt
Aug 29, 2006 02:43 AM
shawn_460
Jul 15, 2005 07:24 PM
