13t front sprocket
Old Aug 25, 2009 | 02:38 AM
afernandez's Avatar
Default 13t front sprocket
Is it easy to install . I can turn a wrench but dont want to mess up my brand new bike either.
Old Aug 25, 2009 | 02:45 AM
cliffsta's Avatar
Easy as pie. Zip off the metal cover thingie, flatten the lock washer, throw a giant ratchet on it, and loosen / remove the big nut. It may be kinda stiff. Leave the bike on the ground and have a friend sit on it to keep the back wheel from spinning. Don't put it in gear and use the engine as leverage you can break the inside of the transmission. Slip on the new sprocket, put the chain on it, reverse procedure.
Old Aug 25, 2009 | 03:05 AM
afernandez's Avatar
Thank you ,but will I need to adjust the chain
Old Aug 25, 2009 | 03:35 AM
JasonFMX's Avatar
No offense, friend...but if you have to ask that question you may want to rethink doing this yourself.
Besides...everyone I have ever heard of, including myself...had to get a damn impact wrench to take that front nut off the first time. Or take some sort of extreme measure.
Maybe get a buddy that knows how to work on bikes and either watch him, or have him supervise you to do so...because, yes you will have to adjust the chain and I'm assuming you'll need to learn how to do that.
Its by no means hard, but if you've never done it before even the most simplest of things can be hard.
Old Aug 25, 2009 | 04:12 AM
klx250scott's Avatar
Just use an impact wrench.
Don't question whether you should be doing this yourself. It was the easiest mod I did. But you need the right tool.
Old Aug 25, 2009 | 04:17 AM
SlapDrum's Avatar
I had a friend sit on the bike (in nuetral) so the back wheel did not spin and it required a socket (mmm I think it was a 1+1/16 socket... I did not have the 26mm or whatever size metric socket that was "really" required)
I used a breaker bar (I had about 4 feet of leverage). It came off.
Yes I did re-adjust the chain but that is pretty easy too.
Tighten it back up tight and your good!
Not hard... Worse comes to worse, take it to the shop and say, "Hey, I need to pay alittle some-some to complete what I started..." No biggie. Say it with pride... Dammit I tried.
Go for it!!!
Old Aug 25, 2009 | 04:41 AM
JasonFMX's Avatar
Originally Posted by SlapDrum
1+1/16 socket...
Yes, this is correct. I find the standard (American), fits better than the metric 26mm. It has a more snug fit.
Old Aug 25, 2009 | 05:48 AM
afernandez's Avatar
Thank you .I can read so I know Ill figure out the chain part
Old Aug 25, 2009 | 05:50 AM
afernandez's Avatar
Default thanks
[QUOTE=JasonFMX;391440]No offense, friend...but if you have to ask that question you may want to rethink doing this yourself.
Old Aug 25, 2009 | 05:52 AM
afernandez's Avatar
Im not an idiot just thought there was no dumb questions only dumb answers .
