klx250 won't start when in gear
Old Mar 28, 2009 | 05:52 AM
Craig's Avatar
Default klx250 won't start when in gear
Hoping someone can help, my 2003 KLX250 won't start (using electric start) when in gear. It starts no problem when in neutral but if I stall in the bush and try to re start it while in gear there is no response (nothing at all). When I put it in neutral and use electric start it will get going again - it's just a pain and sometimes really difficult to have to put into neutral while balancing on the side of a hill or rock before I can start it.
This only started happening on my last ride so I don't know if I have knocked something out of place or disconnected something maybe.
Any ideas would be great.
Old Mar 28, 2009 | 05:58 AM
Probably the clutch switch - check the wiring. Or maybe did you happen to install an aftermarket clutch lever? If so, you need to short the two wires together that feed up to the clutch to bypass it. It's a safety interlock - keeps the bike from turning over if it's in gear and the clutch lever is not pulled. If the switch is broken or the wiring loose somewhere, it won't start even if the lever is pulled.
Old Mar 28, 2009 | 06:39 AM
SlapDrum's Avatar
I think you need to put the kick stand up.
If it is down it may not start.
Old Mar 28, 2009 | 07:41 AM
Craig's Avatar
Thanks, it could be the clutch switch by sounds of it - I broke the lever off on previous ride and replaced it before my last one. I had a spare lever in the tool box I think from my sons YZ85 and it fitted so I put it on. If it is the switch or wiring what should I be looking at or how do I short the two wires?
Old Mar 28, 2009 | 12:05 PM
niven's Avatar
Banned
If you can find the 2 wires that run up to the switch, they may have been torn rite of so you may have to go into the harness to find them, simply crimp or solder them together and tape them up. Just remember though that the starter will now engage with the clutch lever not pulled in when in gear,can make for some embarassing moments if you forget.
Old Mar 28, 2009 | 02:11 PM
jsac's Avatar
i had this same issue.. the "switch" located directly under the clutch lever will begin to rust after time. this "switch" is mad eof nothing more than a couple of metal rails that engage/disengage depending on the location of the clutch lever. 2 small screws to get at it. use some sandpaper to clean the rails up and apply dielectric compound and your good.
Old Apr 1, 2009 | 05:08 AM
Craig's Avatar
Thanks all for the replies, I will play around with the switch and wires and see how I go.
Old Jul 6, 2018 | 01:05 AM
Carla's Avatar
Default Any video of the fix?
I'm still learning about riding, the bike and maintenance. I'm having the same issue but not sure exactly how to go about fixing it. Thanks.
Old Jul 6, 2018 | 02:15 AM
RaceGass's Avatar
Center of the pic is the wires on this Yamaha wr450f
If you look on the underside of your clutch lever/perch on the handlebars there should be two wires (female connectors) that plug into the perch. They might have come loose and need to be simply plugged onto the male spades on the perch itself. There’s no klx here to take a pic of but here’s a example of where it is and where to look.
DirtyHustle
Sep 23, 2015 05:31 AM
Nikolaj Lykke
Jun 10, 2014 10:06 PM
Dezrider
Dec 7, 2010 09:48 PM
tabitchin
Nov 7, 2010 04:53 AM
laytonc85
Jul 27, 2010 09:51 PM
