What is this?
Hello Dragone19. Well I am close to purchasing this bike. I am coming from a 09 ninja 250 so this is a big leap. Are there any problems with this bike? It would be nice to hear a review on it from someone who has owned one for many years.
Cheers
Cheers
what yr are you looking at? I have owned the 88 ninja 750 for road trips. Great and dependable ride. Sold it for a 90 zx7 track ride which I still own. Just make sure that you are geared up and comfy with the 750. It does pull strong and can be heavy and a handfull if not prepared.
edit: the suspension is really soft and under damped, so when you feel up to pushing the ride, bump up the suspension springs, oil and other suspension internals for the forks. The rear shock is not worth re-modding generally.
Good luck with your decision
I have not worked on the carbs on the 98, but although it is a tight fit on the others' carb racks, they are actually fairly easy. But after the first cleaning, just drain the bowls to flush out water and other debris. and only need to do that maybe once a yr for winter prepping.
