starter relay?
Old Nov 24, 2007 | 07:15 PM
fivepointnine's Avatar
Default starter relay?
so this morning I go out and try and start my bike, it cranks slowly and kina intermittently, then nothing, just a click from the junction box when I hit the starter button, if I turn it on (ignition) and then arc the starter relay with a screwdriver it will crank slowly, does this sound like a bad relay? (I have 11.7v on the battery)
Old Nov 24, 2007 | 07:28 PM
Default RE: starter relay?
and the fuel pump comes on like it should...I am getting 11 volts into the relay and nothing out and if I unplug the relay (the fused connector) no lights or anything will come on at all, so can I be pretty confident that it is the relay?
Old Nov 24, 2007 | 08:02 PM
jeffzx9's Avatar
Just because you're getting 11 volts doesn't mean you have the amps. Give the battery a jump and see if it kicks over.
Old Nov 24, 2007 | 08:25 PM
thanks!!! it was the battery, I switched it out with the wifes FZR battery and it fired directly up!!!
wheel408
Ninja ZX-7R
17
Jul 12, 2008 08:52 AM
saki ridin
May 5, 2007 12:09 PM
wcdetjen
Sep 23, 2006 10:50 PM
deej
Apr 28, 2006 02:39 AM
deej
Apr 21, 2006 01:42 AM
