starter relay?
starter relay?
so this morning I go out and try and start my bike, it cranks slowly and kina intermittently, then nothing, just a click from the junction box when I hit the starter button, if I turn it on (ignition) and then arc the starter relay with a screwdriver it will crank slowly, does this sound like a bad relay? (I have 11.7v on the battery)
RE: starter relay?
and the fuel pump comes on like it should...I am getting 11 volts into the relay and nothing out and if I unplug the relay (the fused connector) no lights or anything will come on at all, so can I be pretty confident that it is the relay?
